ford 2000 lift cover help!!!
Have a customer with a 2000 ford (3-cyl) that changed the oil in the trans/rear end. The loader plumbed into the lift cover works, the 3pt does not. They have bled the hyd pump, but the 3pt lift is still dead. It worked fine before the oil change.
Any ideas on where to start with this??
HOW do they hav ethe laoder plumbed in? diverter valve? if so.. 3pt is dead while diverted.
or is it a PB plate?
or a lift cover remote.
the more info your provide. the better the answers you will get.
