TractorLinks.com
Show Parts for Model:
Re: ford 900 loader wont lift weight
soundguy
10-21-2013 07:51:29
Is it your pump? dunno. why don't you pressure test it.
what loader?
what lift cyl type?
plumb hyd gauge capable of 3000 psi into the work port on the valve or couple to the hose in place of the lift cyl.. see what she makes deadheaded.
if it makes good psi deadheaded ( 2000+ )
and still no lift, then test lift cyl if DA. if you have 2 test each seperately. 1 blown parallel cyl will teke out both..
if it is a da lift cyl, remove the hose to the drop port and pressurize the lift port. if oil just blows clean thru.. packing is gone
truge
10-22-2013 19:58:49
 Re: ford 900 loader wont lift weight in reply to soundguy, 10-21-2013 07:51:29
my valve is a 2 lever, ports on left say no.1 lift and no.1 drop right side no.2 lift no.2 drop my loader cyls are hooked to left side one cyl for each outlet the cyl are single acting the bucket cyl are hooked to the other side this cyl has a in and out where as the loader cyls have only a inlet I put pressure guage on all 4 outlets and got about 1700- 1725 psi you think my problem is in the cyl one or the other or both
thanks for your help
Larry NCKS
10-23-2013 03:29:35
 Re: ford 900 loader wont lift weight in reply to truge, 10-22-2013 19:58:49
You have problems in your tractor somewhere. Could be a leak. Could be a pressure relief valve. Could be your pump. Do you hear any squealing under your seat when trying to lift? That would likely be your relief valve or a leak. Kinda hard to tell with no more than I know from this distance.
An observation: There should not be pressure on your #1 drop port if you're running single acting cylinders on #1. There ought to be a screw or a stem on that valve to change #1 from double acting to single acting operation. I know there is on single spool valves.
soundguy
10-23-2013 05:55:07
 Re: ford 900 loader wont lift weight in reply to Larry NCKS, 10-23-2013 03:29:35
i know on many dual da spools, they have the option to turn only one side to sa.
all of my 'ford' style have that. even the tisco repops.
truge
10-23-2013 11:14:19
 Re: ford 900 loader wont lift weight in reply to soundguy, 10-23-2013 05:55:07
appears someone before me had 1 and 2 single acting cyls into the lift and drop ports coupled one and two togather and pluged into no 1 lift left no. 2 drop empty works like new the cyls were fighting against each other thanks for all the ideas and help you guys are great
Larry NCKS
10-23-2013 17:42:50
 Re: ford 900 loader wont lift weight in reply to truge, 10-23-2013 11:14:19
Glad u got it figured out.
