Steve Brussell
I took the generator to have rebuilt (needed armature) and it also needed regulator, which I bought from this site. All charging now, thanks! Next two problems I am tackling are the power steering leak through the top of the column and the oil leak on the hydraulic pump. I will do the p/s leak after I get the oil stopped at the pump. At first I thought it was hydraulic fluid, but it is actually engine oil. It is coming from the front between the idler shaft and case and the book shows an o-ring there. Looks straight forward enough. Any thing I should look out for? Heful hints always appreciated! -Steve
