TractorLinks.com
Order Ford NAA Parts Online
Re: 1954 fofd naa tractor
Texas!
09-26-2013 18:25:16
What do you mean by "seen fire running down all 4 plugs to head"? If by some chance you mean that you saw the spark arcing from the wires or plugs to the head then you have seen your problem. You need new spark plug wires and boots.
ronnie wheat
09-26-2013 18:42:27
 Re: 1954 fofd naa tractor in reply to Texas!, 09-26-2013 18:25:16
YES sparks were running down the plug to head . also noticed you can ground screw driver hold close to plug boot and it will ark. THESE wires are new. but knowing this guy the cheapest you can buy, also cut to length home made.
old
09-26-2013 19:27:32
 Re: 1954 fofd naa tractor in reply to ronnie wheat, 09-26-2013 18:42:27
Oh so plug wires from the land of almost right yep poor made parts cause odd problems
ronnie wheat
09-26-2013 19:41:51
 Re: 1954 fofd naa tractor in reply to old, 09-26-2013 19:27:32
OLD, what do you suggest, does Belden make a set of wires for the old dude.
old
09-26-2013 19:44:16
 Re: 1954 fofd naa tractor in reply to ronnie wheat, 09-26-2013 19:41:51
I buy my wires from an O'Reilly's auto part store. Yes you have to cut them and all since you want true copper wire plug wires but by doing so you have a good warranty
ronnie wheat
09-26-2013 19:26:34
HEY TEXAS, current travels to least resistance, plug is already grounded, what would make it travel on the out side of plug.
old
09-27-2013 08:41:33
 Re: 1954 fofd naa tractor in reply to ronnie wheat, 09-26-2013 19:26:34
How old are the spark plugs??? Could be but if doing it on all 4 not likely but cracked plugs so when warm the crack opens up and then you have that type of spark problem
ronnie wheat
09-27-2013 15:20:40
 Re: 1954 fofd naa tractor in reply to old, 09-27-2013 08:41:33
OLD, the plugs are probably shot, I even took each plug out, grounded watched the fire found two with yellow weak fire, replaced with used plugs that fired to my specks. going to replace all, and wires.
Texas!
09-27-2013 08:27:36
Cheap insulation.
