well I tried the following suggestions on this tractor-governor hunting problem. After the morning rain stopped I backed it out of the shop and took a can of ether and sprayed every surface area around the intake and carb-nothing happened it never sped up. so then I removed the rod from the carb linkage to the governor and operated the throttle by hand. watched the governor and it moved after I operated the throttle and would stay stationary so I tried adjusting the rod shorter and that made it backfire. So maybe Rod is right could it be the rebuilt carb? It has a zenith carb not a holley as most do. only one external adjustment screw. Any ideas guy's Thanks ahead of time for your help.dirtfox
