Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 5000 Parts Online
Re: update on ford 5000 govenor
Ultradog MN
09-19-2013 12:51:03
I'm working on a 4000 here which has the same governor - putting two engines together to make one.
This engine was running when I took it out of the tractor and tore it apart for the crank.
The governor was Not working properly.
Normally the bell shaped part shown in the photo slides in and out on the shaft freely - you can pull it out with your fingers. This one was stuck and would not slide in and out.
I had to pry it out with a small bar.
You can kinda see in the second photo that there is some old dried up oil on the end of the shaft.
That glued it in place so it wouldn't move properly.
Wouldn't be hard to pull the governor cover and check that yours is sliding freely.
I plan to just use the good one on the engine I'm building.
dirtfox
09-19-2013 14:37:35
 Re: update on ford 5000 govenor in reply to Ultradog MN, 09-19-2013 12:51:03
Ultradog I have found the answer to my problem but I do appreciate your entry. I left a entry here just in case someone runs into the same problem that I had. when I started this project I never figured it would turn into such a problem child.Next time someone ask's me if I want to work on a 5000 ford that was burnt up and has a 3 inch layer of dirt and oil, grease on every thing forward of the steering wheel and had been sitting outside for 3 years I think I'll run the other way!!! Have a good day - dirtfox
