TractorLinks.com
Show Parts for Model:
Re: Crankshaft shopping
Bern
09-18-2013 21:19:24
Only potential problem I can see with a new crank is that the balancer gears *may* have to be replaced as well. Ford updated the balancer and crank drive gears for durability reasons, which might present a mis-match issue.
It's possible that an aftermarket crank uses the old style gear, in which case you may be OK. I'm going off of memory here, maybe Rod or Rick B can help, but I think the old gears were 1/2" wide, and the new ones were 9/16"? Or am I confusing those numbers with head bolt diameters?
If you were to get a new crank, you would be a fool to use the old bearings. It would be like buying a brand new pair of shoes and wearing them with dirty socks.
If you have the front end off already, removing the engine block will be fairly tame by comparison.
RodInNS
09-18-2013 21:46:56
 Re: Crankshaft shopping in reply to Bern, 09-18-2013 21:19:24
I can't help on the balancer gears... but I get indigestion thinking about some aftermarket parts that go round and round. I'd probably call Fawcett's and get a used one first.
I don't know where these folks get their cranks and engine parts but if A&I was involved I'd steer a wide circle around it.
A new crank might well be a question for his local machinist...
Rod
