TractorLinks.com
Order Ford 5000 Parts Online
Re: Verdict in on my 5000 piston
poorhunter
09-18-2013 16:19:43
So I checked all the other bearings, and they are all ok. The crank is grooved visibly, so now it"s decision time. I guess I can take the crank out and see if it can be repaired. Are there there any things to be aware of as I take it out?
Bern
09-18-2013 16:26:42
 Re: Verdict in on my 5000 piston in reply to poorhunter, 09-18-2013 16:19:43
Taking the crank out is pretty straightforward. The engine block has to come off the trans obviously.
Before removing the block, I would remove the other 3 pistons. I would then remove the block, flip it upside down, and lay the head deck on a piece of plywood. The clutch, flywheel, front pulley, and front timing cover then need to be removed. The injection pump and rear inner timing plate can stay, along with the cam and lifters. You can then remove the main caps and the crank, assuming the oil pump and balancer are already removed.
