Yesterday's Tractor Co.
Shop Now View Cart
Order Ford 800 Parts Online
Re: Ford 800 Help
09-18-2013 15:50:23
I'll tackle the first two questions.
1. How does the live PTO work? You have a two stage clutch (double clutch). As you release the clutch, the first stage engages the PTO, then as you raise the clutch the tractor starts to move.
2. What is lever on the right under the seat? Horizontal is for position control - the lift is set depending on the touch control lever, ideal for things like mowers. Pointed down is for Draft control, ideal for ground implements such as plows.
On the valve on the hydro pump, I'll leave that to others but I will say you have a vane pump and your tractor is likely an early 860.
09-19-2013 07:11:16
 Re: Ford 800 Help in reply to Kurt-NEPA, 09-18-2013 15:50:23
ditto on that flow control valve on the pump.
probably early unit
