TractorLinks.com
Order Ford 5000 Parts Online
Re: Verdict in on my 5000 piston
Greg_Ky
09-18-2013 12:28:09
If you look back on page nine to your original post that is what I thought had happened, have you taken any main bearing caps off yet? You will probably find that a main is also spun from your discription on Your original post and if that is the case depending if the block can be saved by line boring you would need that as well as at least the one rod reconditioned / replaced and the crank, turned, repaired & turned or replaced. Check the rest of the rod & main bearings first (don't mix up the bearing caps they need to stay on the same rod / main as removed). Post back on what you find. Are you anywhere near central Kentucky by chance? If so I could maybe come take a look.
