Hello guy's - Once again a big thank you to all who have responded to my past question's you are a ton of help. Now my problem after finding all the noises and leaks after this rebuild is that anything above a idol if you are in gear or not the governor hunt's up and down. the only note I can find on it is the length of the rod between the governor and the throttle on the carb is supposed to be 17 3/16 of an inch mines at 17 that is the only adjustment they talk about any idea's???? I'm stumped !!! Thanks for any help!!! there is a screw on the governor housing but I don't see anything in the book about it. Once again thank's guy's
