Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford NAA Parts Online
Re: Jubilee Timing; Stalls at Idle RPMs
NoNewParts
09-18-2013 05:32:02
x3 for a dirty or needing adjustment carb
get that straightened out first.
While timing too retarded will cause an idle stall, it's probably your carb.
an erratic timing light usually means an ignition problem, but in this
case it's probably plugs fouling randomly from the bad carb.
Yes, it's 8 degrees initial for a NAA, but getting em down to 475 rpm, which is sloooow can be a pain.
if your advance is working properly, it's much easier
to find the NAA 29-31 degrees total. rev it up slowly with the timing light on, you will see when the advance has limited out.
set it at 29-31 degrees, lock it down and you're done.
IMO, The timing being right at the working RPMs is the most important.
