Bought a "59 881 Select-O-speed
diesel yesterday (ordered manual
set due Friday). Pre-checked had
full tank of fresh diesel, and new
filter cartridge, all fluids checked.
Oil P/Eng temp green all the way.
Drove unit 28 miles to the farm,
stopping and starting her several
times, without any trouble when
it suddenly died in 9th gear,
about 2/3rds throttle only 300
yards from the gate...
I"ve determined cause to be a fuel
problem. In my troubleshooting
attempts; I first checked fuel level
in tank, then broke the fuel line
downstream of filter at pump
inlet and had flow, so I loosened
pump output fitting nut opposite
input fitting (top of pump), and
had some fuel, little flow. Broke 1
of 4 injector lines at block/injector
- no fuel.
I didn"t ID any inline elec.
solenoid fuel shutoff valve,
witnessed accelerator lever
actuating pump swashplate thru-
shaft, all fasteners and safety-wire
were in-place, no obvious leaks,
mounting bolts secure, so I
turned starter momentaril, but
witnessed no fuel output at
injector fitting.
Seeing no priming pump lever, I
applied some (1-2psi) positive
pressure in tank in a feeble
attempt , to prime, didn"t seem to
pass-through pump/piston assy. I
didn"t break the tank return line
connection.
Is it possible that a foreign object
in the tank (rust etc) might have
starved pump, if so; best way to
prime pump? Or should I assume
the coupling or pump drive
mechanism has failed, is this
common in this design? Any
suggestions on determining if
connecting drive or internal
elements have failed?
Here are thanks in advance for
your assistance - Charlie
