Hydraulic leak into Tranny
jgomez
New User
I would like to thank this Tractor Forum and especially all the persons that repond to questions posted. I would have spent a lot more time figuring out what to do, but thanks to you guys my 4000 gas ford tractor"s hydraulic problem was solved and a 100 per cent success.No more fluid into tranny and hydraulic chamber is full all the time thanks again guys
ditto what the others said.
pull and lathe a repalcement.. or sleeve.
if sleeved. what did you end up using as tube? 3/8? or?
and what epoxy prep did you use?
