Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 881 Parts Online
Re: 1959 Ford 881 S.O.S. diesel stopped abruptly in 10th gear
Texas!
09-17-2013 10:41:32
In order to tow it:
There is a traction disconnect lever on the left side aft of the running board mounted on a round plate. You remove the lever, turn it over, re-intall it and rotate it about 60 degrees toward the rear. Sometimes it helps to rock the rear tire fore and aft to disengage. If you force the lever rearward it can pop out of place leaving the lever free to rotate but it is disengaged internally from the coupler and doesn't release the drive line.
CGA55
09-17-2013 17:28:28
 Re: 1959 Ford 881 S.O.S. diesel stopped abruptly in 10th gea in reply to Texas!, 09-17-2013 10:41:32
(Revision A.) Again, I want to thank yawl for all your kind input. The input regarding traction release got her to the barn - yeah! :-)
It turns out she died because the injector pump stopped supplying fuel (pretty darn sure about this, as she was scooting-along great for 28 miles without any problems, then suddenly died)! I don't care to try and remove pump assy from block mtg pad to determine if its connected, I'd imagine it's driven similar to a distributor. without service manual or witnessing, don't want to mess with timing.
Again, I should have all three manuals delivered before Friday, but noticed a wire exciting through a grommet in that round plate near the traction leaver, but it has been cut short and isn't connected, just wrapped up around the lever handle, and hanging loose...
She wouldn't turn over with traction release, once I returned the lever, she turned over again. There's plenty of good fuel, filter cartridge appears fairly new, so I broke line downstream of filter at pump inlet and had flow.
Broke injector line, but get no flow either by gravity or when turning engine over in start position. Put a little positive pressure in tank, didn't seem to pass-through pump/piston assembly or bleed out 1 of 4 injector outlets. I didn't remove tank return line connection.
I don't see any solenoid fuel shutoff valve, so don't believe there could be any SOS interlock to prevent startups in any transmission position, unless there's some elaborate mechanical coupling connected to pump drive.
Can see that fuel control lever turns swashplate shaft. Is it possible that tank foreign object (rust etc) might have starved pump, if so; is there any way to prime pump, or determine if connecting drive has failed?
Thanks again guys, Charlie in Pea Ridge, Arkansas
CGA55
09-17-2013 16:48:51
I want to thank yawl for all your kind input. Turns out she died because the injector pump stopped supplying fuel! Wouldn't turn over with traction release, once I returned the lever, she turned over again. Plenty of good fuel, broke line downstream of filyet at pump inlet and had flow. Broke injector line, but get no flow either by gravity or when turning engine over in start position... Can see that fuel control lever turns swashplate shaft. Is it possible that tank foreign object (rust etc) might have starved pump, if so; is there any way to prime pump, or determine if connecting drive has failed?
CGA55
09-17-2013 11:26:13
Thanks, I appreciate you - Charlie
