TractorLinks.com
Order Ford 4000 Parts Online
Re: Ford 4000 Industrial SOS
Texas!
09-16-2013 19:34:55
First of all it is a Select-O-Speed. It's marked right on the shifter housing in plain view. There is a traction disconnect lever on the left side aft of the running board mounted on a round plate. You remove the lever, turn it over, re-intall it and rotate it about 60 degrees toward the rear. Sometimes it helps to rock the rear tire fore and aft to disengage. If you force the lever rearward it can pop out of place leaving the lever free to rotate but it is disengaged internally from the coupler and doesn't release the drive line.
