TractorLinks.com
Show Parts for Model:
Re: picture of piston head
poorhunter
09-16-2013 08:48:33
Took the head in this morning. The machinist was concerned about those shadow marks too. There is also a corresponding mark on the head that matches the hollowed out part of the piston. He feels like it is a Rod bearing going out, but could be prior damage is possible. The valves look newer to him, so those were replaced, but don't know about the piston. It doesn't look like the piston was actually hitting the head, but he'll look closer.
He also said that I can try rotating the crank half way through the stroke back and forth the check for play in that piston vs the rest. Any other ideas?
Bern
09-16-2013 09:21:37
 Re: picture of piston head in reply to poorhunter, 09-16-2013 08:48:33
Have machine shop check valve recession. If within specs, there can ONLY be a few more possibilities. 1) rod or wrist pin bushing as has already been discussed, 2) too thin of a head gasket (not likely), 3) piston protrusion too high for that cylinder, or 4) valve lash set too tight for only that cylinder (not likely). My bets are on #1.
Is the engine 4.2 or 4.4 bore? If it's 4.4, I have some more info for you on head gasket usage.
poorhunter
09-16-2013 10:03:18
 Re: picture of piston head in reply to Bern, 09-16-2013 09:21:37
Bern, thanks so much for sharing what you think. I'm not sure what the bore is, but almost positive it's 4.2. I don't have accurate calipers to measure, but the guy at machine shop will tell me. Right now, everything points to the wrist pin...you're #1 thought. If this is the case, how much trouble is it? Split the tractor is what he thinks. For the love of all that's Holy, I hope not...loader is still on tractor, plus I'm no mechanic.
Bern
09-16-2013 15:21:35
 Re: picture of piston head in reply to poorhunter, 09-16-2013 10:03:18
A tape measure is good enough to tell the difference in bore sizes. A 4.2 will be just shy of 4 1/4", and 4.4 will be a little shy of 4 1/2". Please report back if you find it to be 4.4", and I will advise on a head gasket.
Run the suspect piston down half way into the bore and then rock the front pulley back and forth while you watch the piston. There should be no visible hesitation of the piston moving as you rock the crank back and forth. Compare with the other pistons if need be.
If there is a problem, you will need to remove the oil pan. This will require it to be unbolted from the front bolster. You can remove it entirely, or roll it forward a few inches on longer bolts. The choice is yours. No need to split the engine from the trans.
A loader very much complicates things for sure. Depending on the brand, it will likely need to be removed first.
