3000 tractor with 730 loader.
I'm in the process of cleaning up my tractor after changing out the adjustable axle to a solid axle. Previously I had removed my headlights and mounted them on the loader, however now I would like to install them back on the tractor. I have the kind that mount on each side of the front cap. The loader is off now as is the tractor sheetmetal. My front cap has a hole with a concave area that was formed by the headlight mount and I'm thinking the easiest solution to dealing with this would be to simply re-install as they were originally.
Does anyone know if this will interfere with the loader arms (clearance)? Otherwise I'm guessing I will need to beat the mount points flat and plug the holes.
What do you think?
What do you think?
