TractorLinks.com
Show Parts for Model:
Re: picture of piston head
JMOR
09-16-2013 07:00:33
Quoting Removed, click Modern View to seeI could be wrong, Bern, but best I can tell from his words (& picture), there is no valve to piston contact. He is simply worried about the black shadows on the piston that correspond to valve location. Poorhunter, please comment further on 'shadows' & physical 'contact'.
poorhunter
09-16-2013 08:48:33
 Re: picture of piston head in reply to JMOR, 09-16-2013 07:00:33
Took the head in this morning. The machinist was concerned about those shadow marks too. There is also a corresponding mark on the head that matches the hollowed out part of the piston. He feels like it is a Rod bearing going out, but could be prior damage is possible. The valves look newer to him, so those were replaced, but don't know about the piston. It doesn't look like the piston was actually hitting the head, but he'll look closer.
He also said that I can try rotating the crank half way through the stroke back and forth the check for play in that piston vs the rest. Any other ideas?
Bern
09-16-2013 09:21:37
 Re: picture of piston head in reply to poorhunter, 09-16-2013 08:48:33
Have machine shop check valve recession. If within specs, there can ONLY be a few more possibilities. 1) rod or wrist pin bushing as has already been discussed, 2) too thin of a head gasket (not likely), 3) piston protrusion too high for that cylinder, or 4) valve lash set too tight for only that cylinder (not likely). My bets are on #1.
Is the engine 4.2 or 4.4 bore? If it's 4.4, I have some more info for you on head gasket usage.
poorhunter
09-16-2013 10:03:18
 Re: picture of piston head in reply to Bern, 09-16-2013 09:21:37
Bern, thanks so much for sharing what you think. I'm not sure what the bore is, but almost positive it's 4.2. I don't have accurate calipers to measure, but the guy at machine shop will tell me. Right now, everything points to the wrist pin...you're #1 thought. If this is the case, how much trouble is it? Split the tractor is what he thinks. For the love of all that's Holy, I hope not...loader is still on tractor, plus I'm no mechanic.
Bern
09-16-2013 15:21:35
 Re: picture of piston head in reply to poorhunter, 09-16-2013 10:03:18
A tape measure is good enough to tell the difference in bore sizes. A 4.2 will be just shy of 4 1/4", and 4.4 will be a little shy of 4 1/2". Please report back if you find it to be 4.4", and I will advise on a head gasket.
Run the suspect piston down half way into the bore and then rock the front pulley back and forth while you watch the piston. There should be no visible hesitation of the piston moving as you rock the crank back and forth. Compare with the other pistons if need be.
If there is a problem, you will need to remove the oil pan. This will require it to be unbolted from the front bolster. You can remove it entirely, or roll it forward a few inches on longer bolts. The choice is yours. No need to split the engine from the trans.
A loader very much complicates things for sure. Depending on the brand, it will likely need to be removed first.
Bern
09-16-2013 07:50:44
Regardless of whether the valves actually contacted the piston or not, I can tell you for a fact that what I see is NOT normal on a Ford (I've worked on dozens of those engines). Something inside that cylinder is too close for comfort, and needs to be looked into, in my professional opinion. If a wrist pin or rod bearing is on the way out, now would be the time to catch it.
One thing I would do is measure the valve recession on all the valves. If the valves are all pretty much the same and within spec for recession, I would suspect a bearing going out.
Another very distinct possibility is that what we see is contact damage prior to the last (and very recent) engine rebuild. This assumes of course that the pistons were re-used, which I have done often myself on Fords. Those pistons are very tough.
One more thought: If you think that's normal, why does it show on only one piston?
JMOR
09-16-2013 08:29:50
 Re: picture of piston head in reply to Bern, 09-16-2013 07:50:44
I didn't say anything about normal/abnormal, just that everything shown or said pointed to no physical contact. Yes, odd on only one cylinder. Yes, you have pointed out valid reasons to investigate further.
RodInNS
09-16-2013 08:03:24
I agree with you 100%. THAT is NOT normal. Wrist pin or bearing is most probably... but I also wondered about the valves.... mabey sticking a bit on that cylinder for one reason or another.
Rod
