TractorLinks.com
Order Ford NAA Parts Online
Re: Jubilee Timing; Stalls at Idle RPMs
Royse
09-15-2013 15:41:54
I'm giving you a stab in the dark here, but I don't think
the lack of low idle is timing related. I would think carb.
There are two carb circuits, one for idle and one for power.
I would think your idle circuit is not set correctly or needs to be cleaned.
Idle screw on a MS carb turns in to enrich, out to lean.
A lean running carb can cause moderate overheating as well.
Doesn't sound all that far off in the grand scheme of things.
I've ran worse when I had to.
Don't let it overheat and don't entirely trust that gauge.
Larry NCKS
09-16-2013 01:15:56
 Re: Jubilee Timing; Stalls at Idle RPMs in reply to Royse, 09-15-2013 15:41:54
x2 on carb idle problems. Get those corrected and then attack the timing issue. As Royse said, it may just be a simple idle screw adjustment.
mrlewp87
09-17-2013 20:17:37
 Re: Jubilee Timing; Stalls at Idle RPMs in reply to Larry NCKS, 09-16-2013 01:15:56
I"ve seen this "MS" before, in reference to the carb. Not sure what it means. And the term "circuits"? I"d assume talking fuel, not electrical. I"ve adjusted idle screws before on cars, and never thought to try that on our JuJuBee.?? I"m not able to see the replies now, and dont want to risk losing my comments here. So what was that other screw called, and what do I need to know to make adjustments, if any are to be done?
sunbeam
09-19-2013 09:30:53
 Re: Jubilee Timing; Stalls at Idle RPMs in reply to mrlewp87, 09-17-2013 20:17:37
Check the throttle shaft in the carb for looseness any vacuum leak will mess up the idle.
