poorhunter
...that I didn't do something both several of you and the book said to do. When I bought the tractor, it was a fresh rebuild-less than 5hrs on it. I didn't know at the time, and it didn't register til today, that I should re-torque the head bolts after 50hrs. I did not do this, and wonder if this may be the cause of coolant getting into the combustion chamber.
Anyway, now that the head is off, I'll take it in and get it checked out.
Also, as was cleaning gunk off of everything, I noticed that on one of the piston heads there was a perfect picture of the valves. Only this one had it. Is this somewhat normal/expected? What may be causing this?
