Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: hydraulic remote squealing
09-09-2013 06:25:51
I would disconnect the remote hydraulic return line and route it to a clean bucket so you know that you have an unobstructed return flow. Operate some your troublesome remote functions and see if the squeal remains.
Air gets into your hydraulic system through leaks in your suction connections (suction line seals, and possibly pinhole leaks/cracks in the suction line). Leaking hydraulic filter seal is also possible. The root cause is probably due to a plugged pump suction screen in the reservoir. Do you see aerated hydraulic fluid?
The vent is necessary to expel air from the reservoir and is not part of the problem.
bosco alan.
09-09-2013 08:41:27
 Re: hydraulic remote squealing in reply to sixbales, 09-09-2013 06:25:51
Sixbales, this tractor does not have a pump suction screen in the reservoir, the suction tube goes straight to the filter then out of the filter to the pump. The tube is clean.
The best I can tell the fluid is not aerated. Right now I have the tractor split apart putting new clutches in the PTO so I was hoping maybe to resolve some other problems while I am working on it.
