Bill Allis
Finally looked at and drove the infamous 3 cyl 4000. Tach and hour meter worked, is the left gauge the fuel and the right gauge the temp? Is left light the charging system? If the generator is working should it go out? Is the right light the oil pressure? Should it be on before starting and go off after starting?
The fuel was very low and very old. Battery not the best. Tractor started hard, gave it a shot of ether and then it ran OK. Started hot OK. Is the proper cold starting procedure, fuel lever at idle and then crank till it starts?
Still trying to decide how many more problems I need!
