2600 Power Steering
Looked at a gas 2600 last week.It has power steering.There is only one steering cylinder (left side) and the hoses are hanging down too low and seem to go in front of the radiator maybe to a reserve tank.Is this a correct setup or maybe goobered up?The tractor has homemade fenders so I"m thinking it could be fabbed up.If this is an add on power steering system can it be removed?
Sounds like an add-on...which could be removed. Factory would have a cylinder on each side, a reservoir on the pump, and lines from the pump to the steering column and from the column to the cylinders.
