TractorLinks.com
Show Parts for Model:
Re: TW 35 Spewin' coolant update
FordTractorMan
09-07-2013 13:43:48
Warmed tractor up & stuck overflow hose in jar. No bubbles. Ran for 1 hr. No spitting or spewing out tube. Ran another hour. Spit a little here & there under a load, but quit fairly quickly. One more hour. Began to spit more frequently & spewed a steady stream, but never "geysered" like it had before. Checked gooseneck temp w/infrared - 250 +/-. Lower hose (hard steel hose) - 220 +/-. Came back home. Quit spewing after I went to a higher gear on the road (I was just a couple hundred yards from shed). When I got home, only drops of water coming out of overflow tube, but could still see steam. Condensor & radiator covered w/pollen & dust. Blew them clean w/air. Could still see light steam out of overflow & a few water drops. Temps at gooseneck & lower hose had dropped. 190 top, 130 bottom. Also, top hose looked ballooned above gooseneck, normal size coming off top of radiator, if that means anything. Going back outside now to check on it.
ASEguy
09-09-2013 02:40:32
 Re: TW 35 Spewin' coolant update in reply to FordTractorMan, 09-07-2013 13:43:48
Sounds like the heat can't be moved fast enough under load. Loose belt? Did you visually check for flow in the radiator with the cap off when the thermostat was open? The water pump should provide movement similar to a garden hose turned on pretty good at high RPM's.
cbrown9064
09-07-2013 13:52:29
Weird thought (cannot recall what your other thread stated) but do you think the radiator is "plugged"? Perhaps take to a shop in town and see if they can boil it out and test...
FordTractorMan
09-07-2013 17:15:59
 Re: TW 35 Spewin' coolant update in reply to cbrown9064, 09-07-2013 13:52:29
Could be I suppose. That thought crossed my mind. That may be the next thing I test.
