G J in Colo.
New User
I have a ford 800 that I had to rewire. Rewired acording to directions. But will only run with the starter engaged. What have I missed? Any info would be helpful.
Thanks
(quoted from post at 14:41:28 09/07/13) I have a ford 800 that I had to rewire. Rewired acording to directions. But will only run with the starter engaged. What have I missed? Any info would be helpful.
Thanks
ood chance that the smaller-than-battery-cable wire on one of the large solenoid posts is on the wrong large post. It should be on battery side, not starter side.
Thanks for the help with my problem. I hooked it up as you seaid and the tractor fired right up. Just goes to show the manuals are not alyays right.
Thanks again
