TractorLinks.com
Show Parts for Model:
Re: Still trying to diagnose engine knock
Mike(NEOhio)
09-07-2013 09:24:55
Head gasket. Coolant getting into cylinders.
Texasmark1
09-07-2013 13:12:32
 Re: Still trying to diagnose engine knock in reply to Mike(NEOhio), 09-07-2013 09:24:55
+1 on that. Coolant shouldn't be foamy. Fill radiator to the point where you can see water with the cap off. Run the tractor. If you see ANY bubbles, head gasket.
Mark
poorhunter
09-07-2013 10:47:26
Can that cause the engine to make that knocking, or just the foamy coolant?
Texasmark1
09-08-2013 05:39:13
 Re: Still trying to diagnose engine knock in reply to poorhunter, 09-07-2013 10:47:26
You didn't say diesel or gas. Gas no, diesel probably as diesels don't like water in the combustion chamber.....so I'm told and read repeatedly.
Mark
poorhunter
09-08-2013 18:06:51
 Re: Still trying to diagnose engine knock in reply to Texasmark1, 09-08-2013 05:39:13
Sorry, I didn't identify the tractor in this thread. It's a 65 5000 diesel. I will, Lord willing, take the radiator cap off and run it to look for bubbles...I expect that I will. What set of gaskets should I get? Whole set, upper or lower?
Texasmark1
09-08-2013 05:41:16
One thing you can do if gas. Pull the spark plugs and look at them and if you can look down into the cylinders at the top of the pistons.
If you find one or two that are nice and clean as compared to the others yes on the head gasket leaking. Water washes away the carbon.
Mark
sixbales
09-07-2013 15:40:39
Does the engine produce any white smoke out the exhaust?
poorhunter
09-07-2013 16:01:32
 Re: Still trying to diagnose engine knock in reply to sixbales, 09-07-2013 15:40:39
No smoke at all.
