The starter swith will not start the engine. However, when I connect an Ohmmeter from the switch terminal to ground the meter indicates continuity when the switch is depressed. I am
presently starting the engine with the button on the underside of the solenoid (and yes I know the dangers.
I don"t want to replace the switch if it is not necessary as it sounds like a pain
Appreciate any advice.
