Hey every body.
I have a ford 4600 tractor that I need to decipher the Mod# and production #. I found them on the right side on the flat area by the starter. the numbers are as folowes,
DL113C
6E21B
*C506749*
my main problem is in the mod#, all of the numbers I have found on the internet has a letter then 4 numbers and a letter, my tractor has a "L" in the second spot (DL113C). I can see it clearly that it is an "L" . could ford have mistakenly used the L instead of "1" or is there a set of numbers I haven't found for to ID the Model number? I am not sure what Info I can supply you with to help , just let me know what is needed and I will try to get it . the one thing tell you is the paint is red primer then Yellow, then Orange, then Ford Blue. I got the colors from scraping the flat area where the numbers are stamped.
Thanks in advance
ErnieB
DL113C
6E21B
*C506749*
Thanks in advance
ErnieB
