Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Steering Problem
Will Gumbert
09-02-2013 08:47:51
Larry- Here is a picture of the earlier fixed-pedestal design. The spindle shaft is on bearings but I suppose they could have failed or maybe something is binding the sector shaft if, with the cover removed you can't see anything lodged in the sector gears. With this drawing it should help getting it apart. There is a disassembly procedure in the service manual, they suggest doing that before removing the pedestal unit from the tractor.
You mentioned that the power steering doesn't work. Is there any chance the cylinder is locked up preventing it from turning? If you have the front jacked up so the tires are off the ground and with the drag link disconnected from the steering arm, can you turn either the tires or move the steering arm? -Will
Larry/TN
09-02-2013 08:55:35
 Re: Steering Problem in reply to Will Gumbert, 09-02-2013 08:47:51
Yes I do have it jack up and the drag link is disconnected from the steering arm. Still just a wiggle of movement and that seems to be in the gear wear it self. Thanks for the pic..........Larry
Will Gumbert
09-02-2013 10:13:49
 Re: Steering Problem in reply to Larry/TN, 09-02-2013 08:55:35
OK, to try to help just a bit more, if it comes down to having to disassemble the pedestal, here are the pages from the service manual outlining the procedure including removing the pedestal from the tractor if need be. If you have trouble reading the second page, hit the Ctrl and + keys on your keyboard at the same time to make it bigger. Hopefully you can repair it with it still on the tractor. Be sure to support the tractor safely. -Will
