I have a 900/901 row crop with narrow front end.
The front tires will not turn. Somewhere inside the pedestal its locked up. I took the steering a loose from the front of the pedestal. It has to be inside the pedestal. The two top gears inside the reservoir does not have any restriction in the teeth. What should I be looking for and also is this going to be a big problem to work on.
Thanks Larry
Thanks Larry
