I"ve had some real miseries with this 1841 over the 5+ years I"ve owned it. Now a new problem: It was sitting for 3 months and I started it up. Warmed up a bit; shut down to move some things around it. Started again because I had to move it out of a building. Power steering worked from near full right to center and I heard a soft, funny noise. Then NO power steering. I sure was reminded why these tractors MUST have some kind of power steering. Well, I manhandled it out of the building and across to gravel area where I shut it down.
First, this is NOT the cable system steering. It has the heavy steering components and a pump mounted just to the right and slightly above No. 1 spark plug hole. Canister reservoir sits on the pump and it has fluid in it to about 1 inch from rim. Pump has exhibited being a little wet lately so I suspected a slow leak somewhere, but worked fine. Belt is new and tight.I have NO idea where to begin dealing with this. Any tips would be appreciated. I put a lot of money in this tractor about 18 months ago and it now has a new, genuine Ford HD clutch, new in-front-of-engine drive shaft, rebuilt radiator, etc. Remaining problems have been that the hydraulic tank sprung a new leak and the rear rims are close to death. Now this. Sorry to be long winded; just discouraged. Dennis in E WA
