1984 cu411c Ford Tractor back hoe
Anonymous-0
Aloha I am interested in purchasing this tractor but
I not able to get any information on it. What is the
horse power specs, is the sheet metal the same as a
3600 tractor. Can the front end loader fit on a 1974
4000. It is a military tractor. Mahalo Mike
That model does not show up in any of my references. I'm guessing it was a special designation for military only machines, but it should be similar to civilian models of the same time period.
I'm also betting that it has a military type ID plate that has that model number on it. Look on the under side of the right hood panel to see if it might also have the civilian style foil sticker that might have the civilian model designator, and if the foil sticker's not there, look for the stamped numbers on the flat spot on the transmission bell housing just to the rear of the tractor from the starter. If you can find any numbers in either of those locations post them back here and w might be able to help you further.
Aloha Sean Mahalo for the reply and information. I will be at the military base on Tuesday to inspect the tractor and will look for the formation that you asked for. Mahalo Mike
