TractorLinks.com
Show Parts for Model:
Re: no hydraulics
Kurt-NEPA
07-31-2013 12:52:08
My guess is that you have blown the wobble shaft seal. Usually the seal wears a groove in the wobble shaft, so that needs to be replaced too. To do that new bearings are required. You can get a kit to replace the piston springs, check valve balls, and check valve springs also. Well worth it while the pump is apart.
I think pulling the pump for a rebuild is the right thing to so. A rebuild is 3-4hrs labor and about $150-175 in aftermarket parts. More $$'s if CHN parts are used. YT has the parts.
Hope that helps. Keep us posted on how things work out.
rhodech
07-31-2013 13:53:06
 Re: no hydraulics in reply to Kurt-NEPA, 07-31-2013 12:52:08
yeah, well it is the best place to start, will let every one knows how it turns out, and thanks to everyone for the advice and kind words, In should start this weekend if the weather permits
