Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 841 Parts Online
Re: ford 841 power steering issue
hma524
07-30-2013 08:40:07
The release valve maybe not the right name for it. Breather valve might be the right name. This thing is located in the steering box just under the fluid connection lines
Ultradog MN
07-30-2013 10:01:45
 Re: ford 841 power steering issue in reply to hma524, 07-30-2013 08:40:07
Ok,
Now I get it.
Part # 30 in the photo below.
There is nothing wrong with that breather.
What is wrong is the lower seal #28 has failed and is allowing PS oil to escape past it and overflow the lower half of the box.
You will need to dissemble the upper half of your column and replace BOTH the lower one #28 And the upper one #44.
And replace 2 orings #32,
Yes, you will need to pull the tin off to get at the column and yes you really do need to get at least the I&T FO-20 manual and read how to reassemble everything. Manual is available from this site for about $30.
Call your local New Holland dealer and order part #s 83929295 - upper seal
251310 - lower seal
87150s94GV - Orings X2
About $30 in parts.
Holler if you need help with reassembly. They are pretty simple but guys do have trouble with them sometimes.
hma524
07-30-2013 12:08:40
 Re: ford 841 power steering issue in reply to Ultradog MN, 07-30-2013 10:01:45
Thank you Ultradog for your help
this looks like a big job.
Ultradog MN
07-30-2013 13:49:31
 Re: ford 841 power steering issue in reply to hma524, 07-30-2013 12:08:40
Not that hard really.
Where are you located?
Maybe someone here could do it for you - for a fee of course. Or recommend an honest shop who would do it.
Ultradog MN
07-30-2013 10:06:32
If you plug that breather it will just start blowing oil out of the lower case where the sector gears come out. So don't bother...
