Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: 961 starting system question
Will Gumbert
07-30-2013 07:50:09
It has an alternator? This changes things because it should have also been converted to 12V negative ground. Are you sure it had been running for a year with a 6V battery? -Will
07-30-2013 08:22:20
 Re: 961 starting system question in reply to Will Gumbert, 07-30-2013 07:50:09
My friend replaced the original battery with a new 6 volt so I"m not sure what it was. However, the tractor turns over just fine with the new battery and two jumpers on the small solenoid terminals - one hot and one ground. But not when I pull either jumper. I"m going to try jumping across the solenoid large posts and verify there is 6 volts coming from the keyed switch.
07-30-2013 08:31:53
 Re: 961 starting system question in reply to Freewheelin', 07-30-2013 08:22:20
So, in summation, we are blind, working on something where we haven't a clue as to what modifications have been made & thus no way of knowing how it is currently wired. Two wires where one belongs, alternator, positive or negative ground, 6v or 12v? Outcome? Been to Vegas lately? :roll:
Will Gumbert
07-30-2013 08:52:42
 Re: 961 starting system question in reply to JMOR, 07-30-2013 08:31:53
Right. Freewheelin, seems like the best thing would be to trace the wiring out, draw a wiring diagram as it now is, (maybe print and mark up the one JMOR already posted) take a picture of that and attach it to a new post, then maybe we can suggest a way to sort it out correctly. -Will
