TractorLinks.com
Show Parts for Model:
Re: 961 starting system question
Freewheelin'
07-30-2013 07:21:40
There is another wire on the large solenoid stud. The two wires on the "I" terminal are joined inside the rubber connector and thus appear to be factory. There have been changes made such as replacing the fuel gauge with a voltmeter and it has an alternator instead of a generator. However, the tractor started and ran just fine for over a year. It suddenly went dead.
Will Gumbert
07-30-2013 07:50:09
 Re: 961 starting system question in reply to Freewheelin', 07-30-2013 07:21:40
It has an alternator? This changes things because it should have also been converted to 12V negative ground. Are you sure it had been running for a year with a 6V battery? -Will
Freewheelin'
07-30-2013 08:22:20
 Re: 961 starting system question in reply to Will Gumbert, 07-30-2013 07:50:09
My friend replaced the original battery with a new 6 volt so I"m not sure what it was. However, the tractor turns over just fine with the new battery and two jumpers on the small solenoid terminals - one hot and one ground. But not when I pull either jumper. I"m going to try jumping across the solenoid large posts and verify there is 6 volts coming from the keyed switch.
JMOR
07-30-2013 08:31:53
 Re: 961 starting system question in reply to Freewheelin', 07-30-2013 08:22:20
So, in summation, we are blind, working on something where we haven't a clue as to what modifications have been made & thus no way of knowing how it is currently wired. Two wires where one belongs, alternator, positive or negative ground, 6v or 12v? Outcome? Been to Vegas lately? :roll:
Will Gumbert
07-30-2013 08:52:42
 Re: 961 starting system question in reply to JMOR, 07-30-2013 08:31:53
Right. Freewheelin, seems like the best thing would be to trace the wiring out, draw a wiring diagram as it now is, (maybe print and mark up the one JMOR already posted) take a picture of that and attach it to a new post, then maybe we can suggest a way to sort it out correctly. -Will
JMOR
07-30-2013 07:44:39
Quoting Removed, click Modern View to seeSounds like more here than "suddenly went dead". " The solenoid and wires had been removed by my friend so I"m not sure which goes where. " Since the diagram shows only one, not 2 wires on that small solenoid terminal, I would find out where the other end of each wire is connected.
