TractorLinks.com
Show Parts for Model:
Re: 961 starting system question
Will Gumbert
07-29-2013 19:54:10
Couple of things-
Install the battery correctly, positive to ground.
One of the small solenoid posts should be wired to the starter switch which should provide a ground when pressed. Be sure the tractor is in neutral.
The other small solenoid post should be wired to the side of the terminal block that has -6V when the key switch is ON along with the "-" side of the coil and also the wire to the fuel gauge thru a fuse.
It does not matter which large post is which, but one should have a large wire directly to Batt "-" and a small wire that goes to the voltage regulator "B" terminal. The other large post should have a large wire going only to the starter.
Set up this way it should start and run, if not then post back and let us know what you find. If it does run, I suggest you check to be sure the battery is charging properly with a voltmeter. -Will
Freewheelin'
07-29-2013 21:10:08
 Re: 961 starting system question in reply to Will Gumbert, 07-29-2013 19:54:10
Thanks Will. I"ll switch the battery to positive ground and check the voltage to the solenoid and to the coil. Didn"t have my voltmeter with me but the fuel guage has been replaced with a voltmeter and it reads 6 volts plus. What doesn"t make sense is that it turns over with two jumpers but not when either is removed.
