TractorLinks.com
Order Ford 800 Parts Online
Re: 800 with leak in fuel shut off, 4000 series any better
Craig Thompson
07-29-2013 13:41:06
So if I decided to eliminate the fuel shut off under the tank and put it inline what do you use under the tank? Just an elbow?
soundguy
07-30-2013 06:37:03
 Re: 800 with leak in fuel shut off, 4000 series any better in reply to Craig Thompson, 07-29-2013 13:41:06
can't simply add an elbow.. the tap screws tot he tank with 2 screws and has an oring seal there.. plus a seal in the valve.
pretty easy to rebuild.
IF you were to eliminate the valve.. i would probably disassemble it and tin the brass valve and the zinc valve body and then solder them up so the valve was open.. i know some people have reported doing so with a jbweld plug as well.
IMHO.. it's more work to jimmy it than just take apart and repalce 2 orings...
ps. oring wear occurs from valve opening and closing.
you could take apart.. repalce orings.. then leave valve open and then put an inline common ball valve in that was easier to work on .. or more durable.. etc..
your call
Greg1959
07-29-2013 14:40:28
For me, I had a leaking o-ring where the valve meets the tank. I replaced the o-ring and stopped the leak. I used brake line to re-route a new fuel line. Then added the inline ball valve for a shutoff. This way, I just reach down and turn the lever without getting near anything that can burn me.
This post was edited by Greg1959 at 14:49:21 07/29/13.
