TractorLinks.com
Order Ford 800 Parts Online
Re: 800 with leak in fuel shut off, 4000 series any better
Craig Thompson
07-29-2013 11:06:41
Thanks for the fast replies. Well I guess I will be pulling the tank and installing the factory screw type.
36 coupe
07-29-2013 16:55:41
 Re: 800 with leak in fuel shut off, 4000 series any better in reply to Craig Thompson, 07-29-2013 11:06:41
Leave the valve on the tank.Put a new o ring on the screw. never open the valve more than 2 turns.I can plow and bale hay on 2 turns open.Opening it more just wears the o ring.These valves were made by Bendix, originals will be marked so.I have found that MMO will swell original o rings . A few ounces in the gas will do it.
Dale Pendell
07-29-2013 12:07:21
I had a leaky shut-off valve and bought a replacement that was leaky out of the package. So I returned it, and the replacement was leaky too. They're not made well these days. So I used a plastic shut-off valve from a lawn mower---spliced into the fuel line. No leaks, but you'll need smaller hands to open and close in the tight space under the tank...
Dean
07-29-2013 11:57:50
You can change it without removing the sheet metal and tank.
I've got it down to about 30 minutes but I have had lots of practice and do have the correct tools.
The first time was closer to 2 hours.
Dean
