Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford NAA Parts Online
Re: Ford NAA Voltage Regulator problems
36 coupe
07-29-2013 05:12:41
How many fill caps on the battery?
Tim Crawford
07-29-2013 05:34:52
 Re: Ford NAA Voltage Regulator problems in reply to 36 coupe, 07-29-2013 05:12:41
I think it has four fill caps, but I do not have access to the tractor at this time.
JMOR
07-29-2013 06:13:23
 Re: Ford NAA Voltage Regulator problems in reply to Tim Crawford, 07-29-2013 05:34:52
If it has 4, then it is an 8volt battery & with 12v gen & reg, it will always think the 8v battery is low & try to pump full output current into it in trying to bring it up to 12v charging voltage of about 14v. This would be a definite problem.
2.2 volts per cell
3 cells=6.6v
4 cells=8.8v
6 cells=13.2v
varies a few tenths depending on whether of charge, on float, idle (not connected), temperature, etc.
Tim Crawford
07-29-2013 08:19:00
 Re: Ford NAA Voltage Regulator problems in reply to JMOR, 07-29-2013 06:13:23
It may be that it only has 3 caps since when I have tested the voltage after a full charge on a battery charger it only registers 6.5 volts but then if I am charging it with a 6 volt charger that would also make sense that it only charges to 6.5 volts. Since I have no way of visually checking the battery at the moment this will remain a mystery.
You stated in one of your other replies to my posts "I might look toward intermittent conditions for the kind of radical jumping ammeter readings that you report. Maybe wiring shorting or bad/loose/intermittent gen and/or VR grounds."
This reminded me that after I put the first new VR on I did drive the tractor down a path in the woods, it was bumpy, when I would hit a bump the ammeter would in most cases jump to a different level, maybe from -30 to -20, then hit another bump it would jump back up. I even raced the engine while not moving ant the ammeter would go back to +1 for a time until it got jostled some more. Could this be that the field on the generator may be grounding against the generator housing and jostling it causes it to ground at vearious levels? Boy I wish I had access to the trator I would like to try some of these things.
JMOR
07-29-2013 08:23:17
 Re: Ford NAA Voltage Regulator problems in reply to Tim Crawford, 07-29-2013 08:19:00
Quoting Removed, click Modern View to seeWe can guess forever, but with too many unknowns to do any good. Need to know if battery, gen & reg are 6/8/12v?
Tim Crawford
07-29-2013 10:32:58
 Re: Ford NAA Voltage Regulator problems in reply to JMOR, 07-29-2013 08:23:17
I agree until I can get back to the tractor, and get all the right information, plus do some other things there is no way to diagonose the problem. Thanks to all for the back and forth discussion. I will let you know how things are going when I have done some of these things.
