Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford NAA Parts Online
Re: Ford NAA Voltage Regulator problems
JMOR
07-28-2013 17:24:03
" I disconnected the field wire on the generator and then ran the tractor. The ammeter then does not move(no spiking), the generator does not get hot, and the voltage across the battery post on the running tractor reads 9-10 volts." Something wrong with that picture. With field wire disconnected, the gen should not output enough voltage to even begin to charge the battery, so where is this 9-10 volts coming from on a 3 cell 6volt battery?? Maybe you don't have a 6v battery or maybe you need to try another voltmeter?
To further elaborate on mis-match of "A" VR on "B" gen or "B" VR on "A" gen, in both cases, there will be no field current & no output.
I might look toward intermittent conditions for the kind of radical jumping ammeter readings that you report. Maybe wiring shorting or bad/loose/intermittent gen and/or VR grounds.
This post was edited by JMOR at 18:04:25 07/28/13.
Tim Crawford
07-29-2013 05:33:52
 Re: Ford NAA Voltage Regulator problems in reply to JMOR, 07-28-2013 17:24:03
You stated "I might look toward intermittent conditions for the kind of radical jumping ammeter readings that you report. Maybe wiring shorting or bad/loose/intermittent gen and/or VR grounds."
This made reminded me that after i put the first VR on I did drive the tractor down a path in the woods, it was bumpy, when I would hit a bump the VR would in most cases jump to a different level, maybe from -30 to -20, then hit another bump it would jump back up. I even raced the engine while not moving ant the ammeter would go back to +1 for a time until it got jostled some more. Could this be that the field on the generator may be grounding against the generator housing and jostling it causes it to ground at vearious levels? Boy I wish I had access to the trator I would like to try some of these things.
Copyright © 1997-2015 Yesterday's Tractor Co.
