Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford NAA Parts Online
Re: Ford NAA Voltage Regulator problems
Tim Crawford
07-28-2013 17:16:15
This is a lot of good stuff. I am going to have to take some time to digest it and see what I want to do. I noticed that based on my description of the spike in the ammeter that you have not suggested a reason for this behavior, leading me to believe that there is no one single reason for this type of behavior and correcting it is not a simple tweak. It puzzles me that I have put two new VR on the tractor and both reacted the same way the ammeter needle went off the chart. This would lead me to believe that the components that make up this circuit do not match and that there may be a mismatch between the VR and the generator. (A circuit generator vs B circuit VR) I really appreciate your help and the information you have provided. The tractor is on hunting property and won't be able to try any of this until I can get back there. The generator only gets very hot when the tractor is running, One final thing I did before leaving the hunting land was I disconnected the field wire on the generator and then ran the tractor. The ammeter then does not move(no spiking), the generator does not get hot, and the voltage across the battery post on the running tractor reads 9-10 volts. I am guessing that would mean the generator is creating a charge, but the VR is not functioning and closing the set of points(because I disconnected the field wire)that causes the ammeter to spike and overheat the generator. Thanks again for you thoughts.
JMOR
07-28-2013 17:24:03
 Re: Ford NAA Voltage Regulator problems in reply to Tim Crawford, 07-28-2013 17:16:15
" I disconnected the field wire on the generator and then ran the tractor. The ammeter then does not move(no spiking), the generator does not get hot, and the voltage across the battery post on the running tractor reads 9-10 volts." Something wrong with that picture. With field wire disconnected, the gen should not output enough voltage to even begin to charge the battery, so where is this 9-10 volts coming from on a 3 cell 6volt battery?? Maybe you don't have a 6v battery or maybe you need to try another voltmeter?
To further elaborate on mis-match of "A" VR on "B" gen or "B" VR on "A" gen, in both cases, there will be no field current & no output.
I might look toward intermittent conditions for the kind of radical jumping ammeter readings that you report. Maybe wiring shorting or bad/loose/intermittent gen and/or VR grounds.
This post was edited by JMOR at 18:04:25 07/28/13.
Tim Crawford
07-29-2013 05:33:52
 Re: Ford NAA Voltage Regulator problems in reply to JMOR, 07-28-2013 17:24:03
You stated "I might look toward intermittent conditions for the kind of radical jumping ammeter readings that you report. Maybe wiring shorting or bad/loose/intermittent gen and/or VR grounds."
This made reminded me that after i put the first VR on I did drive the tractor down a path in the woods, it was bumpy, when I would hit a bump the VR would in most cases jump to a different level, maybe from -30 to -20, then hit another bump it would jump back up. I even raced the engine while not moving ant the ammeter would go back to +1 for a time until it got jostled some more. Could this be that the field on the generator may be grounding against the generator housing and jostling it causes it to ground at vearious levels? Boy I wish I had access to the trator I would like to try some of these things.
