Yesterday's Tractor Co.
Shop Now View Cart
Order Ford 3000 Parts Online
Re: Ford 3000 oil leak
Ultradog MN
07-28-2013 16:33:54
Always try the simple things first.
Tighten the pan and see if that helps.
Shop manual says 20-24 foot lbs torque.
If that doesn't stop the leak then it's either your rear engine oil seal or your tranny input seal/s.
Neither are hard to repair but will require a split to renew. You can usually inspect and or smell the leaked oil to determine if it is engine or tranny oil though with fresh oils it may be difficult to tell.
07-28-2013 16:40:08
 Re: Ford 3000 oil leak in reply to Ultradog MN, 07-28-2013 16:33:54
Thanks Ultradog,
If it was one of the main seals, wouldn't I see the oil coming out of the hole with the cotter pin?
Ultradog MN
07-29-2013 05:00:57
 Re: Ford 3000 oil leak in reply to ecar, 07-28-2013 16:40:08
Generally yes.
Wiggle the cotter pin around a bit and see if any oil comes out. Could be enough crud on the inside to have blocked the drain hole.
