I have a 66 Ford 3000 diesel and just changed all
fluids (crankcase, transmission, rear end). I ran
the tractor for a couple hours and when I parked
it, I had a pretty good drip coming from the area
around the back of the oil pan. I can't tell if
its the oil pan gasket or the joint between the
engine and transmission.
The leak lasts a couple minutes after shutdown
then stops.
Any ideas?
I don't know why it would be the oil pan gasket
all of a sudden, but if it is, can I just tighten
the bolts in that area (within reason) or should I
stick to torque specs? What are the torque specs
for the oil pan?
then stops.
Any ideas?
for the oil pan?
