TractorLinks.com
Show Parts for Model:
Re: new clutch won't disengage
welding man
07-28-2013 12:24:20
A Ford 2 stage clutch is not a good place for a rookie to start intalling clutches.They have to be set up on a Jig or adjusted internally before rolling the tractor back together.If the finger height on the pressure plate is not correct,it won't release, and the PTO clutch won't release either,that simple.
mick in il.
07-28-2013 12:31:32
 Re: new clutch won't disengage in reply to welding man, 07-28-2013 12:24:20
So the clutch assembly doesn't come pre adjusted? I was under the impression it was already adjusted. I guess now I have to break the tractor again and adj? Not what I was hoping for. Thanks for your input.
welding man
07-28-2013 14:04:06
 Re: new clutch won't disengage in reply to mick in il., 07-28-2013 12:31:32
It Should have been,but I have gotten them that the adjusting nuts were loose and the screws weren't even. Did you get new or reman?If the flywheel has ever been machined,that changes things too.If you don't have a shop manual,you need to get one and read carefully before proceeding. When I install a clutch in any tractor and I do a lot of them, I roll the tractor back together,Install 2 bell housing bolts and check to see if the PTO and main clutches release before I go any farther. If they don't back apart she comes to see whats wrong. Good Luck.
Bern
07-28-2013 14:51:48
 Re: new clutch won't disengage in reply to welding man, 07-28-2013 14:04:06
Excellent advice that everyone should keep in mind when replacing a clutch.
