TractorLinks.com
Order Ford 3000 Parts Online
Re: Fluid Type and Fill on Ford 3000
Ultradog MN
07-26-2013 17:12:44
Kurt,
Welcome to the Ford board.
You're gonna get told this sooner or later so I'll just be the first.
Get an owner's manual! It's chock full of useful info about lubing, adjusting, using and maintaining your tractor.
Available from this site, ebay and maybe Amazon.
Most people here are going to recommend that you use a generic HyTrans or UTF in both the tranny and rear end of your tractor.
Look at the label. It will say meets or exceeds Ford 134D specs.
It is rather thin - like about 40 wt. But guys have been running that stuff in their tractors for 10,000+ hours with good results.
Check Wal Mart, Fleet Farm, Tractor Supply, etc for it.
You will need about 8 gallons to change the fluid in both the tranny and rear end.
Use the same stuff in your power steering reservoir too if you have PS.
Fill level plugs are circled in red in the photo below.
DO NOT loosen the slotted screw marked by the arrow.
Celeste
08-17-2013 19:15:34
 Re: Fluid Type and Fill on Ford 3000 in reply to Ultradog MN, 07-26-2013 17:12:44
Newbie here. What is that part above the red arrow?
Sean in PA
08-18-2013 05:19:38
 Re: Fluid Type and Fill on Ford 3000 in reply to Celeste, 08-17-2013 19:15:34
That's the flow control valve. The black knob controls the flow rate of the hydraulic fluid so you can speed up or slow down your hydraulics. It's a little counter intuitive, at least it was to me. Screwing it in clockwise speeds things up and unscrewing it counterclockwise slows it down.
Celeste
08-18-2013 05:42:39
 Re: Fluid Type and Fill on Ford 3000 in reply to Sean in PA, 08-18-2013 05:19:38
Thank you! I am assuming while sitting in seat clockwise speeds it up
JMOR
08-18-2013 06:18:14
 Re: Fluid Type and Fill on Ford 3000 in reply to Celeste, 08-18-2013 05:42:39
Doesn't matter whether you are sitting in the seat, standing beside the tractor or horizontal. :roll:
