Does anyone have a set of these brackets (see picture)? They are for a Ford 19-87 rear 3 point loader that was made for several years. Think they made at least 3 different models.
If you have the brackets that go under the fenders, could you post some of the specifications so I could make my self a set.
Size of the square plate that goes under the fender.
Length and size of the U strap. (Guessing that U strap is a 1 1/4 x 3/8) or is it 1/2 inch.
Distance of the hole for axle bolt from edge of plate.
Degree of angle and how much does it stick down below the plate.
THANKS in advance.
THANKS in advance.
