TractorLinks.com
Show Parts for Model:
Re: Cast Iron oil pan gasket
RickB
07-21-2013 07:13:54
I agree right up till you get the RTV out. That's not much better than greasing the joint in the long run. I'd MUCH prefer Loctite 518 or 515 which will actually form a bond between the block and pan. The thin OEM gasket and a light coat of HiTack aerosol would be my first choice.
I don't mean AT ALL to be insulting, but my opinion of RTV is not high at all. In most situations there is a better product that can and should be used.
Hobo,NC
07-21-2013 18:43:50
 Re: Cast Iron oil pan gasket in reply to RickB, 07-21-2013 07:13:54
Yes you have a point on the anaerobic sealer is some good stuff to use in a case like this,,, I am sure RTV would work well their about a 1/16" bead is all that would be needed cuzz 99.999% of it is going to be pushed out on asy....
I know you understand my point it had better be the correct gasket are a gasket eliminator that's made for the situation...
