Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 4610 Parts Online
Re: 4610 hard to start when hot
David G
07-20-2013 18:29:46
It is probably worn head on injector pump. You can test it by pouring cool water on pump and see it it starts, BUT you can seize the pump up doing that, so I do not think it is worth the risk.
RickB
07-21-2013 06:08:55
 Re: 4610 hard to start when hot in reply to David G, 07-20-2013 18:29:46
"You can test it by pouring cool water on pump and see it it starts, BUT you can seize the pump up doing that, so I do not think it is worth the risk."
Worst part is, if that happens, you have all but proved the pump was probably OK to begin with. I'd start with a compression test hot, then cold. While the injectors are out, pop test them. if all that checks out, repair or replace the IP.
Copyright © 1997-2015 Yesterday's Tractor Co.
